Taken from a previous post regarding fuel mileage and compression, MarkP stated the following:
Like CZLN6 said: Raising compression WILL increase power and efficiency, resulting in better MPG numbers. The 200 underwent changes into the "3.3L" version of the late 1970s and later that lowered compression for 2 reasons: 1) lower octane fuel and 2) emission controls, specifically oxides of nitrogen. Compression ratios above 9.4:1 cause a peak heat during burn that creates nitrous oxide and dioxide. The introduction of EGR into the intake manifold is done to lower that peak heat about 10% or so: lowering the compression also reduces the peak heat and, with it, the efficiency. That becomes less MPG at the wheels.
The easiest way to rectify the situation with the 200 is to narrow the quench band while raising the compression. With a narrow quench, the oxides of nitrogen and hydrocarbons both go down and the tolerance to poor fuel octane goes up. In other words, like my engine, I got the quench band ("deck height") down to about .035" and milled the head to get the compression ratio up to 9.4:1 or so. The result was an extra 4 MPG, on average, across the board, with noticeably better acceleration and hill-climbing ability. It runs on cheap regular unleaded. It still passed emissions, too, even with advanced timing (+4 degrees over stock) and vacuum advance on the distributor.
Change the distributor advance distance, too. Stock ones usually give about 26-30 degrees total advance. You can weld up the holes a little to reduce this total to 22 degrees, then use an extra static advance to make up the difference. This is precisely what the new, computer-controlled engines do: more advance earlier with less overall. The overall advance for good MPG should not be more than 34 degrees: mine likes about 32 degrees total (static + full mechanical advance). It starts better when hot, too....
I know many of us have wondered, and probably discussed, about the topic of obtaining high compression ratios and still maintaining the use of regular gasoline (general 85 or 87). For many, including myself, have never seen a posted "formula", if you will, with regards to providing a sound solution to the never ending struggle for performance and fuel economy. I'm not saying Marks formula will work for everyone (especially for those at lower elevations) but I would think in general his example is most definetly worth considering.
So, all being equal, what is the "best" compression ratio without sacrificing fuel economy and low emissions? Has anyone applied this question mathematically. Is it possible. Does anyone else have similiar experience? Different results?
