Hmm. I guess it could just poke out the bonnet like a mean streeter! He heh eh ehheheheeeeeeeeeee!
Have a look at my first post on rocking the six. It was just an angrey reaction to the idea that hi po sixes weren't what Mustang Monthly wanted to see.
http://fordsix.com/forum/viewtopic....ays=0&postorder=asc&highlight=mustang monthly
The US, Argie and pre 1976 Aussie I6 engines are much freer space wise than the wide, canted valve x-flow Geelong built I6.
I think you should rock it 30 degrees towards the drivers side for your US engines, and then arrange the blower to fit under the bonnet of bracing in a uni-body Ford. I guess the first post on the TR6 showed that the Wade blower can sit in any position, and the air duct to the intake of the engine doesn't have to be a twin holed intake item like the GMC '71 cube 2-stroke blowers are.
The blower on mine would stick out over the passenger seat on my XE Falcon witout a tilt over, and there isn't enough space to clear the spring towers easily...its very close. I did think of just having it mounted over the valve cover, but the heat and ducting make it a little tight. Some Opel engines, based on the old Opel GT you guys got in the 70's, had (on Opel Manta 400's) an EFI system that travelled through the rocker cover to the other side, so it is possible.
My wife would be fairly upset with me shoving a big blower through the bonnet, and for me,
go is much more important than
show
Do a check on the Slant Six forum. The Chrysler 170/198/225 Slant six is just a normal six, with a block no different from the run of the mill Chevy, Ford or AMC in-line blocks.
I work on the idea that form follows function. If you can package it, do it. If you've got it, flaunt it. Depends on what you really want.
The experiences of my V8 buddies breaking blocks, diffs and gearboxes with modified Cleveland, Windsor, FE and Lima V8's is a valuable lesson. My mate Blair blew 8 grand on his 351C when the block got crazed becasue of someone elses stuff up. A V8 is mega bucks to do up, but sixes grow on trees and are dirt cheap. I can afford to blow the block, head, trans, diff and even blower with what I propose...it's all cheap. That's the key to good hop-ups.
http://www.geocities.com/brettgoodridge
My Dad used to have an old AP-5 Valiant, a four door Plymouth with straight through body lines and a standard 225 slant six. Parts for these old things grow on trees down here too. Engine mounts, sumps, easily found. This is were I am robbing my other bits
