While Kelly's off in Phoenix learning new stuff for her work.....I'm at home tearing up her car.
Today I installed a MUCH larger IC and an electric H2O pump. The reason for the pump is because the cooling fan needs to go where the engine driven pump use to be. Even then there won't be but .100" between the fan and the balancer.
But it's going to be bitchin'!!!
The installed IC measures 22"x9"x3".
The black IC on the right is the old one that was located in the wheelwell.
The other IC is one that will be for sale by FSPP. It's 19"x9"x2". It'll be able to handle 350hp without a problem. The larger brother that's installed in Kelly's Falcon can flow enough to handle 550hp.
Later,
Will
Later,
Will
