All Big Six Knock Sensor with Microsquirt?
Relates to all big sixes
jgregg13
Supporter 2021
The Microsquirt instruction shows a one wire sensor and a GM ESC module whereas the Ford sensor is two wire. Can you somehow use the stock Ford sensor with Microsquirt or can you use a sensor from a Chev 350 that has the same bore size as the 4.9L?
Did you ever find the answer to this?
When I was researching mega squirt, it looked like it could work with most knock sensors.
Is there a different frequency they react at; meaning different high/low frequency range.? Does the Microsquirt have adjustable setting range to use different sensors.
I dont believe the MS2/micro has the ability to handle a raw knock sensor signal directly and do anything valuable with it. That processing, filtering, etc is done externally and the Micro just receives a digital yes/no input from the external source.(or an analog 0-5v, but still same theory)
It been a while since I was using and looking into the knock sensing for MS2/micro, but that's what I seem to remember. The MS3/micro has more ability, but is still limited compared to more advanced and refined knock sensing that is more common in todays factory controllers and some of the higher end standalone knock sensing devices.
DIY Autotune should know for sure what your options are and normally great for support.
