Man, I just went back and looked at were the wheel sits on the pulley and I retract my previous statement. I thought the wheel was put on the outside of the pulley furthest away from the block. I see now that it's right against the block and cover. I agree that if the belt clears, you can weld a mounting boss to the cover and attach the sensor or sensor mount there.Can the pickup be mounted to the middle of the timing cover?
After revisiting, aren't the actuators dual-acting diaphragms?
Two of your bolts are right at the center hub of the cam gear.Is there room for a bolt head inside the cover, been awhile since I had one off. I could just drill through it, and mount a piece of angle to it.
You will need a 3 port valve so the bottom of the bypass valve actuator can vent to the outside when it is not connected to the manifold.I wanted to revisit this. This would work, it would just be all or noting, a complete dump. This could even be done off a switch couldn't it?
When on the solenoid opens and the bypass sees vacuum, opening the system. Then when off, the system is under full boost, unless the second port sees vacuum in plenum and then opens?
question is where do I get a solenoid like that?
Aluminum welded on, or countersunk bolts from inside, should be able to whip out a nice little bracket.Is there room for a bolt head inside the cover, been awhile since I had one off. I could just drill through it, and mount a piece of angle to it.
Definitely in the back of my mind...I would think nylocks and locktite would do the trick though.Sounds like red loctite will be a close, trusted friend. I'd be paranoid of those bolts loosening and getting chewed up by your timing set.
Yes. The cam gear gets pressure fed and the crank gear is exposed to the oil pan.Does oil make its way into the timing cover? Enough to worry about leaking through bolt holes or a slot?
Putting crank and cam position sensors in a convenient spot, while merging two different systems. L29 heads/intake, on L18 block.wow thats pretty welding. but why?
and it was not only pretty but perfect welding if you got no shrinkage
That's good Karma. I regret not doing that more myself.... Sticking up for a middle school kid on the bus, 40 years ago, paid off![]()
