clintonvillian
Nice metal work on the cab! Is the 300 Sset back in the chassis where you need the firewall modded or are they just longer than the old 223 six? Fuel line that's equivalent to 3/8 inch should be good with a 1/4 to 5/16 inch return line. On fuel a tank many people mount one of the early Mustang fuel tanks at the back of the frame so you could get one that set up for EFI with an internal fuel pump see below for one example. Best of luck
1965 up Ford Mustang EFI Fuel Tank 22 Gal
It would have fit. I just wanted better weight distribution and plenty of room to work.
My tank is already in. I need an inline pump. The 87ish f150s had inline pumps. Id love to have something off of the shelf.
Will they supply enough fuel for 6-60 lb injectors? Weren't factorys 15?
