This week-end, I was running with the car and after 10 miles, the engine (1955 223 I6) started to misfire. While slowing down (no more power), the engine began to be very noisy and ran erratically. The Oil Pressure lamp lighted on and the engine stopped.
Believing it is a lack of gas (I have no fuel gauge), I added 5 gallons of fuel, checked the oil level and restarted the engine. The engine crancked but missed erratically. Probably something was drained from the bottom of the fuel tank... 5 minutes later, everything was OK.
20 miles from there, the problem appeared again but this time with very noisy detonations in the exhaust system while driving without pressing the accelerator pedal. When I press, no more the detonations. At idle, the engine stop and I have A LOT of difficulties to restart. It occured 10 times in a raw (always at the cross lights...).
I checked the fuel alimentation (recently renewed) and the carb bowl
I checked the ignition wire and distribution head (all parts are new)
I checked the fuel pump (restored last week).
Everything is OK but the engine still has difficulties.
Having to return home, I drove with the issues. After 20 minutes of detonations, misfire and idle problems, the engine restart to run good.... until now.
To sum up, I wonder what occured and I am afraid it occured again on a highway. Could you advice what can I do to avoid new occurence, what to check, etc.
Thanks for your help
