xctasy":101cqjeh said:The solution is a bit tedius, but Addo and Asa showed me how. "Just" run the main image copied twice, then spend time changing each image to thumbnail.
The rule is there is fix total cost of the powerboard package. Although a real bear, it fixes the time taken to start up each page.
Then they can be as big as you please. Two things. You have to save periodically, and secondly, you have to have no one else within 50 feet, becasue if you get confused with all the image syntax, you'll swear like a mad man.
Mustang_Geezer":3np14oi9 said:Gene Fiore":3np14oi9 said:NICE!! Has anything changed since your last time out? Those are awesome times...13's are just around the corner! :wow:Mustang_Geezer":3np14oi9 said:Been awhile since I've been on here and updated this so these times are from a test & tune last night @ US 131 MSP.
Temps was in the mid 80's.
60' 1.95 1/8 mile 8.99 @ 76.68 1/4 mile 14.15 @ 94.23
60' 1.93 1/8 mile 8.94 @ 76.82 1/4 mile 14.10 @ 94.61
60' 1.93 1/8 mile 8.96 @ 76.56 1/4 mile 14.13 @ 94.03
Later,
Doug
Gene,
Gutted the car and removed 100 lbs, got my electric water pump drive working right (finally) Rejetted carb down a couple of jet sizes, did some work on my distro so its running 34 degrees total, 8 initial, no vacuum advance, switched from the long yellow secondary spring to the short yellow secondary spring and shut off the electric fan when I prestage. It leaves the hardest around 2600 rpms.
Car weighs 2680 with me and a 1/4 tank of gas.
Readjusted the slapper bars so they hae a bit less than a 1/4 inch gap between them and the leaf spring. Unclamped the rear of the spring and made some clamps to bolt together the front of the spring.
I have to finish wiring a switch to the alternator so I can shut that off when I prestage.
I cant leave any higher on the convertor because it breaks the tires loose. I'm running on 225/60/15 BFG Radial T/A's.
I need some more drag radials but cant afford them this season.
I got a cool picture of it launching last weekend but the pic is too big (600x800) to use on this forum
Later,
Doug
Yep!Mustang_Geezer":1ohb77t7 said:
Gene Fiore":2k9g5f72 said:Yep!Mustang_Geezer":2k9g5f72 said:
Yes, it worked too...nice video...I need to get one of my car someday!Mustang_Geezer":hs3rn8tj said:Gene Fiore":hs3rn8tj said:Yep!Mustang_Geezer":hs3rn8tj said:
Gene,
How about the video?
Mustang_Geezer":2o026vyx said:
:thanks: Mustang_Geezer":31oonk9n said:The wheel hopping is caused by the tires old wore out BFG's. I was just curious if this would have a bad effect on the converter.![]()
Glad the video and pics came out allright. Thanks guys for all the help!:thanks:
Never really thought about it as being the quickest N/A small 6 in the USA![]()
New converter seems to be working all right but it was COLD yesterday (mid 40's) and it would not hook up at all. Spun every pass but still managed 14.30's so I was happy.
New drag radials, 4.10 gears and see if I can shave a few more pounds off it is the plan for this winter. I ran it across the scales yesterday at the track and it weighs 2685 with me in it at this point in time.
I'll post my time slips this afternoon.
Later,
Doug
