I'm hoping someone has senn this exact thing before. I had a new long block built using my core. The head had already been done, a D3 head on a C9 engine, the head was milled .075. I had driven the car a few hundred miles with this head so I assume there was no problem there. Turns out the camshaft ws bad, hence the rebuild. The new engine has a new cam and timing chain set from Classic Inlines. I'm not home so I can't say which cam I have but it is a mild one.
The engine will get hot to boiling over in 3-4 minutes. The mechanic went ahead and knocked the center out of the thermostat, no change. The ignition timing is spot on. The engine seems to run correctly in every way except it gets hot and fast. Both upper and lower radiator hoses get hot so I have to assume there is water flow. The engine doesn't act tight and there are no unusual noises.
I always considered the engine to run a little warm but it never boiled over even in the summer.
I am going to call the company the built the engine tomorrow, Blaines Motor Supply, to see what they say but I'm posting this in hopes someone has seen the exact same thing. The car is about 200 miles away from where I am right now so I can't check anything myself right now and report back to the forum. I have very limited internet access until Tuesday but if someone sends me a PM I can send and receive those.
Is there a water pump that fits and was meant to turn in another direction (like I have the wrong pump), or can you flip the head gasket front to back and it would bolt up but block a water passage? just grasping at straws....
I'm hoping someone has seen the exact same thing before..
Thanks.
Stephen
Plano, Tx
Thanks.
Stephen
Plano, Tx
