new guy needs help "not a dictionary"
Use a 5.9 24 valve cummins turbo with a turbo t bird wastegate . the stock wastegate will only dial down to 20 pounds or so, a little 2 much to start with. run an intercooler!!! dont break it to quick, itll run good just be easy on it till you have it all figured out.boost refrenced fuel pressure regulator and nonleaky carb of almost any kind for starters boost gauge and fuel pressure gauge for tuning.throw away the stock mechanical pump,you will need a pump that can put out a miniumum of one pound of fuel pressure for every pound of boost,example stock carb 5-7 pounds of fuel pressure 14 pounds of boost, 21 or so pounds of fuel pressure .
have fun dont blow it up! :fume:
