I have already read some posts on installing an ignition conversion kit. I was experiencing ignition problems and opted to install an ignitor from pertronix and a new flamethrower coil. I am not a real good mechanic but am trying to keep my fairlane up and running.
I will try to give a brief discription of what i have already done with my ignition system, after all this the car is still not running.
I have replaced the original, cracked, distributercap, put in a new rotor wich was completely worn out. I have replaced the old standard coil with a new flamethrowercoil.
I replaced the original points with an ignitor. I reconnected the groundwire from th distributerhousing to the distributer-advance-plate. I screwed the ignitor in place and put the wires through the hole in the bottom, secured the grommet. Then I put the round magnet piece in place and put on the new rotor. The distributorcap was put on as well as new sparkplugwires. I then connected the black ignitor wire with the negative side of the new ignitioncoil. Connected the original resistancewire to the coil as well as the red ignitor wire.
--At this point the car did not start, the starter engine did not even turn over.
I think that I made a mistake here, because I assumed thet my ’64 fairlane did not have a ballast resistor or a resistance wire. I have looked up the electrical plans on the internet and found the ‘pink’ resistance wire.
--I started to locate the resistance wire and after removing a part of the dash I found the red-green wire coming from the ignitionswitch to the resistance wire. So I removed the ignitor red-wire from the coil, and connected it to the 12V red-green wire wich was coming from the ignition switch. I left the resistance wire connected to the positive side of th coil. Still the engine will not turn, the starter engine does not turn over. I can hear the starter relay closing.
I don’t know wat more to do to fix this!!!
i would really appreciate it if anyone could give me some advice
a Belgian Fairlane enthousiast
