NEW MEMBER WITH A PROB....
HELLO ALL I HAVE A 62 RANCHERO AND I HAVE SOME PROBLEMS WITH I THINK MY CARB. ITS A 144 WITH A SINGLE STACK..LOL IT SEEMS TO BE GOING OKAY BUT WHEN I START IT IT WILL IDLE GOOD ITS WHEN I PUSH ON THE PEDAL TO GO IT DIES JUST DIES. I HAVE TO RESTART IT THEN PUMP FAST THE PEDAL THEN IT SEEMS TO GO...WHY OH WHY IT COULD BE MY FUEL PUMP ALSO HELL I DONT KNOW BUT SOMETIMES ITS A TRUE PAIN....HOPE TO HEAR FROM YA'LL SOON BYE JAKE
Sounds to me like it could be the accelerator pump needing replaced. :?
Try rebuilding the carb or buying a rebuilt one. Sounds like some sort of carb problem. Fuel pump shouldn't matter since your fuel bowl should be full. Might want to check your float level inside the carb.
Slade
Stop screaming. Lower case, please. Welcome to the board. Check your accelerator pump and your fuel pump.
Hey okay i'll use small letters, and t/y i love this forum. anyway i never thought of the acc. pump, and yes it does it all the time when i start it. that is my trid carb i have had to relace it twice then went to riverside and found a carb guy that changed the float and checked it again. sometimes also when i am driving a steady speed it will feel as if the accleration is going up and down, not a smooth ride. thank ya'll for the answers this place is great........jake out
also could one of ya explain how i could put a pic on my profile, so people can see my ride. thanks again jake[/url]
To use a pic, or an avatar as they are called, you have to have the pic reside on a web site location. Then just paste that web address in your avatar location under preferances.
jake_ster":2c32dbws said:
sometimes also when i am driving a steady speed it will feel as if the acceleration is going up and down, not a smooth ride.
Jake,
Check your timing too, Ford sets the stock timing at 6* BTDC. Try setting it to 10*-12* BTDC.
Thank ya'll very much for the help i will check the acc pump and the timing.....i'll let ya'll know if it helped at all......jake out
