I am getting a pertronix 1 kit from CJ Pony parts soon. I have read online to get better performance from the set up that you should get 12 volts to the coil instead of the resistor wire supplying 6 volts. I checked the voltage today . I removed the wire at the coil from the key start. I placed a meter between the coil and the wire and had 11.76 volts with the key in the on position ( engine off). How do you check the correct voltage to the coil? Yesterday I was adjusting the points and I had my dwell meter connected to the distributor side of the coil to check the dwell. I changed my meter setting to voltage with the test wires still arranged to test dwell. The Voltage reading was 6 volts with the engine running. If I need to change the wiring what is the best way on a 66 Mustang? One person said to connect a new wire from a 3 spade connector that is on the ignition circuit and run it to the coil. Is there a ballast resistor or is the wire a resistor on a 66 Mustang? Just dont want to screw up the ignitor.
