Yes engine is running. Other sensors and read outs like the MAP are responsive. RPM is completely unresponsive so is TPS. ACT and ECT dont register anything and there is one INF on the board idk what that is for thoughYeah sorry I realized that too late. Your screenshot shows RPM( n )being 3104. Is the engine running?
Engine is off, RPM stays at 3100.I would shut it down. You can test those things with the key on and engine off
Okay I'll start there again, let me see if I need to clean it again.No dont edit that. If you're running j1x code, it should be populating correctly. I'm wondering if you don't have a good contact between the quarter horse and the ECU. Did you clean the contacts really well?
Sorry where do I find that? I don’t think I’ve seen that referenced.I just remembered if you're running the stock bin you have to apply the data logging patch before it'll work correctly
I just woke up and went out and applied the patch. Everything seems to be working with datalogging now. Gonna same this config and start messing around now. Your extended VE tables are just for bigger injectors?On the left side, select parameter type. Scroll down to patches and open the data logging patch and then apply the patch. If you're not emulating then save the new bin and re-upload it
just read through all of this. Understood what I understood hahaha, concerning the last comment you left, did you ever find a boost setup to test with? I should be able digest all that info in the thread soon and try to implement it on a 4.9 bin. I want to try and account for a 5.0 throttle body first before I start welding shit for a simple boost setupThat's awesome! I've actually found the factory 93 ford map sensor will read boost. There are some tweaks you have to make to the code to allow it to read more than one atmosphere, but that's pretty well documented here. There's a bit of trial and error you can skip over, but there's some good bits in here.
I'd be glad to help you as you would be the first one to test boost utilizing MAP with the factory system.
It's super simple to turn off EGR and the thermactor system. If you can figure out how to dump the factory bin I can just shut those off for you.
Cool I work with spread sheets a lot so I should be able to figure that out. I noticed with the extended VE tables my idle was surging a bit and in first without throttle. I just updated the 750 rpm range in the table and that seemed to smooth it out.Nice. You've come a long way in a short time. I'll work on fixing a few things up in the adx. I should be able to quickly add thermactor and EGR scalars so you can turn them on and off as needed. I've been focused on the V8 tune (a1c) but a lot of that can translate over really fast.
You probably want to start dialing and fuel on the extended table. You'll need to get history, tables open and select fuelerror_map_n or something like that. Then go for a drive and try to hit all the load and RPM ranges. This table logs fuel correction that I can help you reapply back to the tune and get it dialed right in. I'll post the Excel spreadsheet. I wrote that automates this process. You just do a couple of copy and paste operations.
