My build: 1966 200 with 1975 250 head. Block is zeroed with 40 over, balanced. Head milled .060. All new caps, moly rings, bearings, Sealed Power dished pistons. Clay smith 264/264 110 cam. Adjustable rocker arm and hydraulic lifters. Static compression ratio 9.16:1. Running DGV 32/36 - Direct mount. DUI distributor. Rebuilt C4 automatic with Transgo shift kit. Classic Inlines headers, avinrode dual exhaust. DUI distributor. Stock converter.
After adjusting the initial and messing with the carb settings, I have finally got this car to run pretty good.
Initially the shop said the cam was 2 much for this build. I told them to crank the initial advance up to 25, and the owner was not comfortable and did not want to damage the motor. When I picked the car up, the mechanic said he set the timing to 20 degrees advanced. The car stalled 3 times when I tried to reverse out of the shop parking lot (wasn’t happy). I hooked up the timing light and reset the timing to about 26 advanced and adjusted the carb to highest vacuum under load with car in drive. I am getting 1100 rpm at idle in park with 15 vacuum. In drive, I am getting 10 vacuum at 845 rpm.
With the new adjustments, the car is running like a beast.. it’s GOOD. The only complaint is when shifting to reverse, the engine wants to stall. If I feather a little it’s ok.
My question is am I going to blow up my brand new motor with this much advance??? It sounds like these engines like a lot of initial??? My next step is to send my DUI to FSD and get it re-curved.
My tech level is beginner, so please be very clear with suggestions/questions. Thanks!!
