is there a roundabout way to remove the camshaft without removing the head...could u take off the valve cover, remove the pushrods, insert long extendable magnets into each hole to hold the tappets from falling and just slide in a new cam? also...if i go to roller rockers, will stock tappets be fine and just get new pushrods? i feel that if i redo either the cam or pushrods or head that i have to do it all at once...and that means having parts kicking around till i can afford the rest...
