What do the Rocket Scientists make of this?
http://www.free-energy-info.co.uk/Chapt10.html
some cook on the internet":1q4rovng said:Very interesting studies carried out by Mr Masaru Emoto have shown that the thoughts of ordinary members of the public can alter the structure of water without there being any actual physical contact with the water. If the water receives positive thoughts and is then frozen, the resulting crystal structure will be like this:
While on the other hand, if negative thoughts are aimed at the water, whether just by looking at it and thinking, or by writing those thoughts down on paper, the resulting crystal shape is quite different when the water is frozen, as shown here:
It is not all that startling if you consider that the quantum mechanics researchers have been saying for a long time that experiments can be affected by the observer. People who build Joe Cells which operate through environmental energy focused by specially treated and structured pure water, record the fact that certain people can affect a Joe Cell in a negative way from a distance of fifty yards (or metres) away.
Personally, I am quite sure that we do not understand the fundamental nature of our environment and that we have very little idea of how we as individuals impact on our surroundings.
There is an extremely honest and reputable researcher called George Wiseman who operates through his company Eagle-Research. George is very experienced in producing “Brown’s Gas†and he publishes excellent instruction books on the subject. The really interesting thing is that Brown’s Gas is produced from water and that gas has the most remarkable properties which are not readily explained by our present day “conventional†science. When Brown’s Gas is used as the gas to power a cutting torch (like an oxy-acetylene torch) the resulting flame is nearly colourless and can be waved across a bare hand without any ill effects - the hand is not burnt. But when applied to a fire brick which is intended to resist high temperatures, it burns a neat hole through it. It will vaporise a tungsten rod which normally takes 6,000oC to do that, which indicates that the flame temperature depends on what it touches (!).
It can also weld aluminium to aluminium without the need for an inert gas. It will weld aluminium to brass and it can weld a steel rod to an ordinary building brick. It can fuse glass to a building brick. This is not “normal†for a chemical combustion reaction, showing that Brown’s Gas is not a “normal†chemical substance. As Brown’s Gas comes from water, does that perhaps suggest that water is not a “normal†chemical substance? I will leave you to make up your own mind about that.
StrangeRanger":3lswz045 said:Inquiring minds want know:
"What happens when you run a perpetual motion machine in reverse?"![]()
ASMART":2d4kinub said:I agree that there is no way to get an energy gain. You can only transfer the source. If you seperated the Hs and Os using a solar panel, you could transfer the power "potential" to your car with browns gas. Your car would be a solar electric hybrid.
Hmmm.
