TrickSix
Found a whole air cleaner, kind of expensive though - https://www.ebay.com/itm/4047185694...uid=yPAA4oA3Qxu&widget_ver=artemis&media=COPY
Relax about the carb jet. She ran good last winter and unless you noticed the exhaust smelled way rich, that project is not high priority. (It doesn't matter what carb it is, all carb mixtures get richer as altitude increases- quite a bit actually, aprox. 3% per 1,000' elevation.)@B RON CO - thanks for the plug recommendation, just bought ‘em
@Frank -
- “Handy with the carbs”?! Smaller jet? I thought it was earlier stated that the Carter YF was all good.
- Factory enclosed air cleaner, snorkel with a hot air valve? Any chance there is a modern, more accessible (quick purchase online) approach?
- Sounds like this is addressing the whole assembly. I think the existing setup is attempting to conform to the “doghouse” but I’m not married to it and am willing to fabricate a new one (this can help me address my noise issue as well as I can add more insulation)
@pmuller9 -
- New plugs are on the way, but the solution is basically a future rebuild… right? Or is there something more approachable that I should shoot for this year?
- Do the cylinder oil squirts last? Seasonal or other frequency?
Clueless Queues:
Crankshaft turn testing (Distributor rotation):
- Is the purpose just to assess the timing chain? If bad, does this mean a rebuild or is it just getting out in front of it?
As for tuning… I’m clueless here. I’ll research, but any guidance would be appreciated!
Tempus fugit for sure. And I suppose you are looking to wrap up working on your Chariot before the snow flies. (Don't give Dr. Smith a ride. If he stows away push him out of the airlock at the earliest opportunity!) But those two offset air cleaners are pretty spendy for how rusty they are. They say they're taking offers, maybe lowball them and see what happens. Too bad it sold just last week, but that one I linked to in post #60 looks like the pick of the litter now. I'd wait and shop a little more to see if a better bargain shows up. You don't have to change the old air cleaner now, it's just a good idea. It's up to you to balance cost and time and need. For reference while you shop, that cheaper dimple option V8 air cleaner bottom may have a dent, but it's not really in the right place. It should be smaller and closer to the carb throat. Compare it to the first one with no top I linked to in post #60. However, since your YF carb has a bigger inlet than the 1100/1101 family of carbs, that makes whether their air cleaners fit over the choke moot. That bigger flange limits your air cleaner options. I'm thinking of going to my secret old Ford junkyard this weekend to look for a spare heavy duty cooling fan. I'll ask the guy if he's got one of those offset air cleaners. If he does I bet he'd charge less than $50 for it.Suddenly it is 3 weeks later - a whole lot of life with work and kids’ sports somehow getting in the way!
@Frank - the YF Carb flange is 2.63 and I like the idea of the offset air cleaner cap as you showed in the shared image. I’m pretty sure that would be the best fit for the doghouse and carb setup… the choke line might be a challenge and have to be dealt with with any setup beyond the tiny one I already have.
@TrickSix - looking around on eBay I see a couple of options based on @Frank’s offsets suggestion, but boy are they spendy. Love your advice on these options:
I did obtain a leak down tester in this interim and aim to do the test as well as the distributor-based timing chain test.
- Offset Option 1
- Offset Option 2
- Cheaper (cheapest I’ve seen!) dimple Option
As to an alternator, I ran into a similar problem, so I got a bosch unit for $20 that was originally from a rangerover, it is rated at 120a. I had to renew brushes and regulator and the slip rings. The big advantage is that it will hold everything at AT IDLE, so it has an output of around 60a at idle, this is to me most important. I dont like the "one wire" thing, how do they exite? One other thing, a single vee belt is limited to around 60a, so you may need two belts to get the full output or go to a ploy vee belt. 1 more thing, dont forget 120a is quite a bit and you will need some heavy cables for that on positive and negative side. A voltmeter is very useful to follow what is going on with the system. My twopenith worth!@Frank, @TrickSix - thoughts on these air cleaners? (Newly listed, Option 1 - https://www.ebay.com/itm/146022574867) or (Option 2 https://www.ebay.com/itm/256287994920). I've got outstanding queries to both to verify the intake flange diameter. Dog House-wise, this seems like the best form factor to run with.
Otherwise, I'm in a time crunch now and got to get things wrapped by mid December. Timing chain test via distributor seems okay, got new plugs, and will try to squeeze in the leak down test... but not sure if I'll even be able to do anything with the results just now. I'm really getting excited for next year's off season to go big with engine optimization stuff.
Main focus now is electrical - I'll be doing tests on the current alternator, but I'm pretty sure I'm going to need to a new one. I love the one-wire advice, but with all the electrical on board (lots of lights, cameras, etc.) I am wondering what the cons of a super high amp one would be - I see 200-240 options out there. Total estimated load with all the electrical doohickies onboard is ~120A.
I'm planning on getting a pusher fan out front, unless y'all call me off, but the research I'm doing all points to the need for it.
Cold Starts: I'd love anyone's advice here, but I'm convinced that a block heater will help smooth things out quite a bit. At basecamp (parking lot) I can bring a small generator and get about an hour of juice to power things externally. Up top at the cabin, I've got a consistent AC source.
I've considered all kinds of set ups:
The race is on!
- Inline thermostatic heater (moderately expensive)
- Inline pump heater (expensive)
- Freeze Plug (cheap)
- Oil Pan Silicone Heater Pad (cheap)
- Combo Freeze Plug + Heater
X2 ^^One other thing, a single vee belt is limited to around 60a, so you may need two belts to get the full output or go to a ploy vee belt.
The first air filter housing has a big advantage- it comes with the factory hot air stove! Those are rare, and worth it. The metal housing bolts to the manifold and hugs it, to warm the air going to the carb. Warm air intake is always beneficial, especially in your environment. Getting that complete system is recommended. Mine is painted black in the pic. The two vertical 1/4" nuts that hold it in place can be seen (rusty). This is the factory-original set up.@Frank, @TrickSix - thoughts on these air cleaners? (Newly listed, Option 1 - https://www.ebay.com/itm/146022574867) or (Option 2 https://www.ebay.com/itm/256287994920). I've got outstanding queries to both to verify the intake flange diameter. Dog House-wise, this seems like the best form factor to run with.
The race is on!
Probably so. But if I may reiterate a point from my post #68 that wasn't addressed in the last couple posts, you are putting an air cleaner from a 300 on a 200. The support bracket will need to be custom, though that shouldn't be a very complicated job. Making the warm air plenum from a 300 exhaust manifold fit the exhaust manifold from a 200 might not be so easy. But I guess we don't do this stuff because it's easy...@Frank, @TrickSix - thoughts on these air cleaners? (Newly listed, Option 1 - https://www.ebay.com/itm/146022574867) or (Option 2 https://www.ebay.com/itm/256287994920). I've got outstanding queries to both to verify the intake flange diameter. Dog House-wise, this seems like the best form factor to run with.
AW SMACK! I totally forgot that he's got the 200. My bad.Probably so. But if I may reiterate a point from my post #68 that wasn't addressed in the last couple posts, you are putting an air cleaner from a 300 on a 200. The support bracket will need to be custom, though that shouldn't be a very complicated job. Making the warm air plenum from a 300 exhaust manifold fit the exhaust manifold from a 200 might not be so easy. But I guess we don't do this stuff because it's easy...
The housing will fit the carb neck if you've got the "big" YF. You may have to tinker around to get the hot air stove around the manifold/exhaust pipe on the 200. When I changed the engine in the truck above I used different manifolds, the stove would not fit in it's stock shape. It bends (with heat), cuts and welds easy. The "new" gray stove below is made up of the original with some shade-tree-mechanic mods to fit it. It can be done. That stove is the only part from the original engine that got reused, lol. The warmed air is worth the effort when it's cold out.@aussie7mains @TrickSix @Frank - thanks for the advice, the air cleaner (Option 1 - https://www.ebay.com/itm/146022574867) is purchased and on its way! I feel confident in fabbing a support bracket.
@TrickSix - Seller responded with "Flange open is approx 2 11/16 inside. Approx 3 on outside lip." So I think we are on target for Carter YF's 2 5/8" ...I hope.
The deal with warming the incoming air is, the air/fuel mix just below the throttle plate is 36* colder than it was as it entered the carb, due to the evaporation of the gas into vapor, and the vacuum. Where I live it's rarely below 40*, but it's rarely under 90% humidity at daybreak. The reason for the heat is to prevent carburetor icing. The stove works, without it the carb ices up nearly daily for several months of the year. (Ice can form at any temp below 65*, and is the worst between 48*-53*). Your environment is nearly opposite (and much nicer to live in!) so icing is not a frequent threat, it becomes a matter of having enough latent heat in the air to vaporize the gas. The stock manifolds do a good job of transferring heat into the intake, assisting good vaporization of the fuel. If I had to choose between warmed incoming air or a block heater, the block heater would get the nod in a dry high-mountain environment.@Frank - that pic helps me understand the "hot air stove" much better... seems like it would definitely get in the way of a freeze plug block heater though.
Any other opinions on Cold Start front?
