barishiman
Addo:
I did the adjustmentby your specs. At first it looked backwards as I started to adjust the valves. I then pulled out my Chilton's manual and it said to start on TDC as the compression stroke ends. After that it looked fine. I adjusted the valves per your order. Here is the new compression readings on a cold engine:
1.) 170
2.) 0
3.) 0
4.) 150
5.) 170
6.) 30
Ok, can anyone exlpain the oddity of this to me! Yesterday I had compression on all cylinders. Now I've got 2,3 with none and 6 trying to give me a reading. I re-adjusted the valves again and got the same results. So then I did a wet test and still the same results. Something is very wrong and I'm about to go nuts. I have no unearthly idea what is happening. I didn't even attempt to start the car as the compression readings weren't promising at all. I"m going to grab some lunch and watch a movie. Maybe tonight I'll go work on the car again. So what should I do? make the valves on 2,3, & 6 loose and try a compression reading again?
And yes I have little patience when I'm been at this for two weeks.
Andrew
1.) 170
2.) 0
3.) 0
4.) 150
5.) 170
6.) 30
Andrew
