the car won't start and I thought I had tracked it down to the ignition switch. not thestarter or the relay. with the jumper the car cranks, so there no problems there. I replaced the ignition switch and the car won't start still. previously I had gotten the car to start but couldn't figure out why sometimes I get nothing when I turn the key. So then last night I wiggled some wires around the ignition and suddenly the car starts (hence the ignition switch) then suddenly the car won't start again, I turn the key and nothing. so where should I go from here. any suggestions.
mike
mike
