KustomSkylark
kukm66":3qr9bkyy said:Just out of curiousity, are your heater hoses hooked up to your engine?
One of the biggest mistakes people make when replacing the cooling system is to hook up the tank to the system and all of the accumulated crud recirculates back into the system, defeating everything you just did.
If they are hooked up, unhook them and put in some brass plugs with sealant. Secondly, make sure that your hoses are well tightened and the clamp is up close to the raised portion of you outlet. This is another common affliction as the system will lose pressure if the system is not completely closed.
If your engine sat for a long time, the antifreeze will crystalize and form a solid mass which will corrode all aluminum parts and also block passages. I would definatley look into a pressurized engine flush.
I looped the heater hose around, you can see it in the pictures. I don't need a heater here in AZ. I don't think the block ever sat for a long period of time, I took it out of a running Fairmont.
