greetings.
i have a xf efi 6, auto and i have come across something i need some help with.
if i leave my car running for a few minutes then the needle on the temp gadge reaches half. first off i put a new thermostat in, cleaned out the radiator, put all that crap in it thats suppose to clean it, checked the water pump which seems fine and the fan clutch also seems fine so i was wondering what am i missing. it heats up pretty quick even if i go around the block which is less than a hundred metres.
Also when my motor is running it makes a fast ticking noise to me it sounds like something some where is hiting something.
thanks for your help.
