Gettin' kinda off the subject of piston rings here, but I'll tie it together. Maybe.
I read
https://fordsix.com/threads/porting-a-promaxx-head.87440/ up to pg. 10, post 200 today. And kept re-reading 'til I realized my brain was full.
I can't offer any hard data, but:
Holy High-CR Heart-Shaped Historicity (Batman)
The heart-shaped combustion chamber of the British Austin/BMC/British Leyland “A”-Series engine had at least a peripheral influence on various Ford engines redesigned in the mid-‘80s; among the Ford engines was the Ford 300-6 EFI, known as the 4.9L. Check out these pics (BNC, top; Ford, bottom).
The heart-shaped combustion chamber was designed by Harry Weslake in the ‘30’s or during WWII, and was used from the outset of the A-Series from the outset to the end-of-production in 1990—a production spread of 52 years. Why? “…High torque, good economy…”
I’m also assuming: “Low emissions” and “ability to burn lowest-grade gasoline” with its low surface-to-volume fast-burn characteristics, and, since the Weslake patent (Patent info:
) is already out there, thus saving engineering time and the Austin engine already had a proven 50+ year track record, thus saving proving time… (Loosely, very loosely, summarized from
The A-Series Engine: It’s First 60 Years) .
I’d like to summarize (“bowdlerize”, is probably a better word) again some excerpts from David Vizard’s book,
Tuning the A-Series Engine (3rd Edition, ©1999) first published in 1985; think where the 4.9 head was in the design process), pages 231-232:
Heads for Economy
Extensive dyno testing…has indicated that three factors affect (sic) economy: the roughness of the intake port, the CR and flow capability of the exhaust port.
Many companies in the cylinder head business find it difficult to sell cylinder heads unless they have a fine, polished finish. These polished ports…contribute nothing [and] I concluded that the polished ports may be adversely affecting economy.
Eventually it was found that the best economy figures were achieved when the intake port was left virtually standard. The intake valve itself was back-cut and the face of the valve machined to leave a sharp edge so as to reduce the effect of backflow.
On the exhaust side, the valve diameter was increased from a 1.516 inch to 1.215 inch…
Here, the exhaust p ort valve and the exhaust port were tailored for high flow capability. In fact, put in simple terms, the exhaust port was given race engine treatment. Under these conditions, this cylinder head produced a 2% improvement in the steady speed fuel consumption between 30 and 70 mph.
At the time of this writing, my suggested formula for success in terms of economy from the head is to utilize absolutely standard intake port with a standard size intake valve, preferably of the Rimflo design
. This should be used together with a larger Rimflo exhaust valve in a fully reworked exhaust port. The combustion chamber itself needs to be polished, as this will achieve two things. Firstly, it will cut down the surface area presented to the flame and therefore less heat will he conducted to the water jacket; secondly, the polished surface will also cause some of the heat to be reflected back into the chamber rather than conducted away. Remember, heat loss is also economy loss. We are burning the fuel to expand the air in the cylinder and the higher temperatures that ae achieved for a given amount of fuel, the more economy the engine will achieve.
RIMFLO
The quoted passage is basically 30 years old, possibly closer to 50, but I still think it has some applicability to the 4.9L (itself released for MY 1987).
For my usage, OEM-width intake, possibly but not probably, larger exhaust valves, necked-down stems, multiangle valve job, port and bowl cleanup, and HTB coating on combustion chamber and CC-side valve on a P-Max head might work and long-branch headers would work for MPG. Maybe work on a 240. See, I told ya I'd tie in a 240 short-block with thin-section low-tension rings together...
Eddie
REFERENCES
A. TEXT
1.
The A-Series Engine: It’s First Sixty Years, Graham Robson. Haynes Publishing, 1st Edition, 2011.
2.
Tuning the A-Series Engine, David Vizard. Haynes Publishing, 3rd Edition, 1998 First published in 1985.
B. IMAGES
1. A-Series Combustion Chamber
https: //www.longspeed.com/fast-road-a-series-engines/
2. Ford 4.9L Combustion Chamber
https://promaxxperformance.com/product/ford-300-fi-new-full/
3. Rimflo Valve
https://www.calverst.com/technical-info/suitability-basics/
