My girlfriend's '67 runs and idles fine for the most part, but when I'm driving it, it'll sometimes just flat out stall out of nowhere. Sometimes it'll stall, and if I keep the ignition on and keep it in gear with it still rolling with my foot on the gas a small bit, sometimes it'll buck to life and continue to drive for a few hundred feet, then die again.
It seems like after it happens the first time while I'm driving, it'll happen several more times in the same drive. When I shoot starter fluid down the carb throat the car always starts up without issue and will sit there idling smoothly. I found a medium fuel leak in the rear of the car and figured that the car was sucking air and causing it to stall out intermittently while driving so I replaced all the fuel lines in the car since they were all pretty bad to begin with. Figured I'd fixed it... then it happened again a couple hours later in the same night. I also replaced the fuel filter since it's like $2 and when I pulled the old one off expecting to get my hands covered in gas I realized the thing was bone dry inside. Zero gas came out. This was immediately after the thing had stalled pulling it into place in my driveway.
I have not noticed speed or RPMs as having any significant affect on this issue, either.
With an electric fuel pump it's easy to diagnose - just jumper the two leads to + and - on a 12v source... but I've never had experience with a mechanical fuel pump failing... does anyone know if this sounds like it might be the issue?
