mugsy":3a7x1deu said:I think the *other* reason that the water heated/cooled spacer is there is from a steady state point of view. Regardless if the spacer is supplying heat or preventing heat from the intake it would make the carb run at a more consistant temp. And with the consistant temp, it would take one variable out of the operating parameters for the carb. It *should* make the carb easier to tune.
CobraSix":13ybbkr2 said:mugsy":13ybbkr2 said:I think the *other* reason that the water heated/cooled spacer is there is from a steady state point of view. Regardless if the spacer is supplying heat or preventing heat from the intake it would make the carb run at a more consistant temp. And with the consistant temp, it would take one variable out of the operating parameters for the carb. It *should* make the carb easier to tune.
I think this theory actually may be closer to the solution. Carb's love steady state operation. Come to think of it, IT does seem I have to adjust my carb a lot more now what I have no coolant hooked up then when I did have it hooked up (both 1V and 4V engine mods).
I like this theory.
I never had the vaporlock issue, even on really hot days with the coolant hooked up or not.
My background is Marine Engineering. I also took all the thermal courses like Mechanicals but mostly applied it to Marine enviroments (Designing ships, propulsion systems, HVAC, Auxilliary services, etc) and then working on them while I was a Naval Engineer in the CG, so I've seen engines from 1HP-30,000HP torn apart, and cooling systems the size of our cars...hehe.
Bort62":199zjgbf said:My car doesn't have the coolant loop installed, and I don't put many miles on it. Is there anyone in the bay area who would like to participate in some testing? I've got the thermocouples and DAS
jahearne":2mcv1gj2 said:Bort62":2mcv1gj2 said:My car doesn't have the coolant loop installed, and I don't put many miles on it. Is there anyone in the bay area who would like to participate in some testing? I've got the thermocouples and DAS
I'd be willing, but don't have the carb spacer w/ water passage anymore with the new Offy setup.
jahearne":18vd6437 said:Bort62":18vd6437 said:My car doesn't have the coolant loop installed, and I don't put many miles on it. Is there anyone in the bay area who would like to participate in some testing? I've got the thermocouples and DAS
Patrick66":m7zbjxas said:jahearne":m7zbjxas said:Bort62":m7zbjxas said:My car doesn't have the coolant loop installed, and I don't put many miles on it. Is there anyone in the bay area who would like to participate in some testing? I've got the thermocouples and DAS
i still have mine.
ill do it, give me a couple weeks.
Patrick66":3s69uwfi said:Road trip! no, not really.
im pretty sure i can borrow something from a friend. if i just measure the temp of the spacer without the coolan lines hooked up, then with it hooked up that should be sufficient, right? ive been meaning to get an infared temp gun to measure the temps in my snakes cage so i might go ahead and buy one anyway.
page62":2hxf80ql said:It seemed to me that the coolant was moving so fast that it was 1) not providing sufficient time to absorb heat
Bort62":ux2qq7ia said:Uh-Oh not this myth again!![]()
