pedal2themetal45
HI all
Well after 2yrs of waiting and working part time on it .. I got it started today..
New motor... (started right up).
But it had a bad knock in it
But its minor I used the 61 170 oil pan on the 200 and the crank is hitting the pan I can feel it...
Can I remove the pan without pulling the crossmember or the motor?? The cross menber is behind the deep part of the pan and Its about 1" below the shallow part of the pan??
Can I just masage the pan a little with/out taking it off??? Like putting a clamp over the pan and squize it a little.from the side making a belly in the bottom.
Pull the pan and masage just where its hitting?? cause I don't realy know if it hitting the sides as well.
Thanks Tim
Thanks Tim
