ok...this has sorta been covered a bit but not really...i really want to do this...i want to flatten out the area above the 2nd and 5th intake
then have a metal plate i can bolt on...have some tubes welded to the plates which will go to a box...the inside of the box can be shaped for smooth flow...but i want to be able to attach a carb in the center of the engine..and also have the option to go from any carb. this way would be the easiest i think cause the middle doesnt have to be taken out...i would just make a block off plate with a single tube sticking out of it for my hydrogen setup to connect to...does any one forsee any problems with haveing a setup like this...anything like sluggishness and low or high speeds...what would compliment a setup like this? just a few thoughts and comments would be appreciated...i really want to upgrade but not something that will take a long timei want to make it...then all i gotta do is file grind dril..tap..whatever...attach..basically a project that wont take too long at all. how long has it taken u guys to install a new head? or even just take it off and put it back on?
