I'm about a hair away from taking this car to the shop and saying fix it regardless of cost. It is a 61 Comet with a 144 and a Holley 1904 single barrel. I replaced the ignition point, caps, etc and rebuilt the carb. I should have left it alone! It ran fine before I tinkered with it. Now, it will run, rough, but when let off the gas it shuts off and sounds bad. Last week the carb caught on fire and knocked over my two year old running in the house to get the extinguisher. The carb does a little backfiring every once in a while and I have to turn the mixture screw way too far out. I think the real problems started when I rebuilt the carb. I replaced the ignition stuff first. I can't remember how it ran after just the ignition. There are no vacuum leaks that I can see. The points, dwell, timing, plugs, look to be right. I believe the float is set correctly. I replaced the fuel pump thinking that is the problem and it's not. Now I have this &*%$ leak that I can't stop. I'm extremely frustrated as you can tell.
