This will be fun
Pictures of the head without tape?
So here’s what I had done on the head. It was cleaned and checked for cracks. Milled flat on the mating surface. He increased the size to 1.60/1.94. The guides were cut for viton seals.
Hardened seats and all the valves were faced. The stud towers were drilled and tapped. I gave him a spring retainer and the valves and he went through them and set the installed height for each valve then numbered them for me. I used the die grinder beforehand in the bowl area. He installed two of the rocker studs. I gave him a pair for reference while drilling them out. Before I masked it off I put a rocker on one of those installed studs to see if the cover would fit and it seems like there’s about a 3/8” gap. I’ll double check this weekend after I paint.
Looks like there is .4” gap as the valve cover sits on top of the rocker arm locks. They aren’t adjusted.
Thanks for the pictures.
Which rocker arm studs did you use?
Are they sitting flush with the top of the stud towers.
From the pictures there appears to bit a slight gap under the hex.
They are ARP 134-7123
There’s a small gap. I’m waiting on the sealant for final installation. They are in there hand tight.
You will want to counter sink the holes for the studs a little.
It is important the the stud tightens down on the shoulder under the hex without binding on the last thread under the hex.
Any radius at the last thread can split a piece off the stud tower.
Every thing else looks great!
Were the towers lowered any?
I compared the covers from the carb motor and the EFI motor. The EFI is taller on the two ends. Maybe I can fab up a taller one using both,makin it tall all the way through. F3588954-6611-4082-90CC-5B0F5F45F73C.jpegF3588954-6611-4082-90CC-5B0F5F45F73C.jpeg
That’s a good point. He installed the two I gave him all ready. Hopefully I can get em out. He used 640 locktite. The towers are at the same height.
Were the old press in stud holes all the way through to water? The new threaded ones are all the way through. That’s why I was thinking he used the 640. To seal the holes. Will the two installed studs come out with a breaker bar and heat?
I’ll mock up the intakes to make sure there’s room between the upper and the top of the cover. Then I’ll this. Thanks for the picture.
this is fun
The holes for the pressed in studs did not go thru to the water jacket.
640 Loctite is a medium strength sealant.
I would apply some heat so you don't have to twist hard on the new studs.
Gotcha. So what do you think about the best type of sealer then? To make sure I don’t develop a coolant leak.
I’ll heat em up when I loosen.
Thanks for all your advice
Here’s where I’m at in the process. Pmuller9 I did like you suggested and reamed the rocker stud tower holes so the studs sit flat on top. We installed the valve springs to 1.7”. This afternoon I flipped it over and measured the chambers and came up with 74ccs each. I’m guessing the next thing to do is get the block to the shop and see what needs to be done on the cylinders and deck? Then I can call and get pistons ordered?
Opinions?
I haven’t pulled the block apart yet
Also I was able to get cncdudes very last valve cover spacer!! Thanks for that. I mocked up the intakes to the head and there was almost an inch of space so I think it’ll work great
Everything looks great.
For my own curiosity, How much was shaved off the head surface?
Do you have the Crower Cam?
Get the block done and get the connecting rods resized with ARP bolts.
Then you can measure the block deck height and the finished rod length to get your piston pin height.
Get the crankshaft done also so you can order rod, main and cam bearings.
You know he told me but I don’t have it here. I’ll call him tomorrow. It wasn’t huge.
I do have the cam and lifters.
Should I take the block to him assembled then or take it apart?
The shop gets the bare block, crankshaft and connecting rods.
Most of the time you take the block apart and remove the freeze plugs and oil passage plugs paying very careful attention to where each oil plug came from. Also carefully remove sensors paying attention which hole each was in. Take pictures if needed.
Take the time to prepare marked ziploc bags so as you remove each set of small bolts from covers and other parts they are identified in a bag.
Remove the rod and piston assembly being careful not to let the rod bolts hit the crankshaft journal as you push the pistons out the top.
Tape the connecting rod bolt threads or use plastic tubing.
Remove the rod bearings and put the rod cap back on the same direction it came off.
The shop will need to press the piston pins out of the connecting rods to remove the pistons.
Remove the main bearings and put the main caps back on with the cap bolts snug.
Remove the camshaft with the gear in place for now.
You can leave the cam bearings in.
Then you can clean the block with a good degreaser, scrape gaskets off and begin your own inspection.
Look for sand/iron lumps in the crankcase surfaces and inside corners. If you find any then grind them away.
Remove all casting flash especially in the cam tunnel.
Finally radius all edges in and outside the block.
