Can the timing chain be replaced without removing the oil pan? My Ford service manual indicates to drop the pan. This would be a pain with engine in the car. I did a search and somebody did it without removing the oil pan, but they had an oil leak in the front of the engine. The other question is what type of puller to use to get the dampner/balancer off. Would it be the same type as a steering wheel puller?
Thanks Lowell
Thanks Lowell
