Bayrunner:
There should be a "notch" on the balancer.
It lines up with the corresponding marks on the timing chain cover, which tells you where the timing is set.
Unfortunatly that isn't accurate because the Diameter is not the same , easy to just measure and do the 360 in a circle based on the Diameter and apply per inch
