Any of you tripower guys dealing with heat soak problems? My 3 webers seem to suffer from heat soak problems after sitting from a good run. It'll start and run but my AFR readings are all over the place going really lean. This only happens if I shut the car off and let it sit for a short time (5-10 minutes) after driven for about 10 miles. If I take it to work (13 miles) and let it cool all day, she runs fine. I've got phenolic spacers under the carbs, plastic insulating washers around the carb studs, insulated the fuel line, and wrapped the headers. My AFR is running a around 12.5-13 until I shut off and restart, then it jumps around - 12 to 16.5 wildly. If I'm going downhill with my foot off the skinny pedal, I can feel it trying to cut out and stumble. I thought of making a shield to cover the headers hoping to block some of the heat. Of course that could backfire and turn it into a big baking sheet...
