fast64ranchero,
Recommending a turbocharger is kinda like picking a cam shaft - your idea of daily driver and the way the car behaves may be different than mine. The recommendations you usually see are for stock engines using stock low rpm cams, no porting, restrictive exhaust. With the modifications you've made I would think you could go up a size or ? I would try the turbo you have. Monitor turbine inlet pressure with a gauge using a small metal oil pressure line. If the pressure is more than - let's say 2.7 X boost pressure - turbine AR or turbine is too small. Also, if you monitor compressor outlet temp, there are calculation charts that you can tell if your compressor is too small and out of efficiency. In the sticky that Linc made up there is a link to Ray Hall's turocharging. Go to turbo calculations and then "find a turbo map" (or something like that). Play with it some and you can see how your engine will work with different turbo maps.
Engine size is 206 ci, wet race weight with driver = 2200 lbs. I figure there was .2 left in the car without raising the boost pressure with launch tuning. Here's a link to more info http://www.fordsix.com/forum/viewtopic.php?t=31654
