So maybe this isn't the right section to pose this question, but it seems as good as any.
I'm really on the fence over this adjustable PCV valve. reference: viewtopic.php?f=1&t=73925
I'm intrigued by the operation and am convinced that my donor engine for my cylinder head had a PCV valve that was plugged, based upon the amount of build up on the backside of the valves. I'm sure that there were probably some valve guide issues as well but the sludge was ridiculous.
My question is: So how does the PCV setup really work with the inline? I get how it works with a V8. And here's about as good a diagram as I've seen
Here it's easier to understand because the clean air in is through a different valve cover. I'm just not grasping how this works when you've only got one valve cover. Aren't you just recycling the air primarily out of the valve cover itself instead of really venting any of those crankcase gases? Wouldn't a better system for an inline have the PCV valve coming from the crankcase as opposed to the the exact same valve cover as where the clean air is drawn in? It just doesn't seem like an efficient gas evacuation scheme, unless there's some subtle design issue that I'm failing to understand.
Anybody got a good explanation of how the theory of operation works here on the inlines? Does this whole thing work on some kind of venturi principle or something? Seems like that would be a rather inefficient draw.
that should have also been on my above list i.e. the correct type of valve cover. X2 on Bills comment about using the correctly rated (spec) of PCV valve it's very important for the system to operate as it really should. Good luck
