found something..
i am mainly after an under tray myself..
the above is an undertray for a forumula ford race car.
above is a bmw race car front undertray..more info and pics at
http://www.bimmerworld.com/html/bimmerworld-e36-front-splitterundertray.htm
hope this helps you.
and some more drivell from my toughts on the matter-
you want to limit as much air as posible thats going under the car,
a front splitter, directs air over the top of the car, so having the car as low as posible will also reduce air going under neath it.
on the formula ford car, they have a pair of strakes to direct air to to side of the car (out under side skirts) just in frount of the rear wheels,
adding a rear bumper with ventri's will speed up the air exiting the rear of the car, creating a low pressure area behind the car, air traveling over the car will want to fill the low pressure area thus creating a sharp turn of air on the rear of the car..thus more down force.
a tray like the bimmer one above, would prevent air getting up under the bonnet and using it like a big parachute (read... create lift).
i think i will employ the following on my ea falcon...
i already have a vented bonnet, directing heat out into the incominf air stream , this will give me good down force, hot air rises, so when the cold air hits it, it should ramp up sharply and creating a downforce affect on the bonnet.
also, under the car, there is a big engine nappy, its a plate that extends to the back of the engine from the bottom of the front bumper, stoping any air getting up in the engine bay and using the bonnet as a big parachute.
i may make up a rear bar that diffusers that will speed the air up ar the rear of the car, makeing a low pressure area behind the car and sucking the arse end down, also i am thinking of a set of diffuses under the car (just behind the drivers foot well. that direct air out the side od the car, just in front of the the rear wheele, to reduce the air thats under the car.
oh the car is already down to it lowest street legal height i can go .. 100mm off the ground.
and.....
what i am thinking..
is (lucky i am a sheetmetal worker :mrgreen: )
a front bar that comes down to 4 or 5 inches of the ground,
on the under side of that a big alloy sheet that goes back to where the bell housing is, on a gradual gradient up to the floor level,
this plate would meet with an other that went right back to the diff, with simular strakes to what is depicted in the photo of the formula ford car, to disperse air out the sides of the car in frontof the back wheels,
another plate would be behind the diff with strakes in it that match up to the rear bar that has difuses on it to speed the air up,
the air that enter the radiator and into the engine bay would be deflected up into the bonnet vent i will be makeing in the bonnet,
this way, i can get max down force with out an attention attracting wing on the back, and with out a massive front end over hang on the front bar, so basicly any air that hits the front of the car will-
50-60% of air will go over the top of the car
20-30% will go thru the radiator into the duct that feed air up over the bonnet thus creating a downforce effect on the front
the other 10-20% of air will be channeled and guided under the car to create a down force effect on the arse end
who knows it may just work.
but first i have to sort out its spray job and interior then assemble the bloody thing, before i can test out my aerodynamic theories.
ps. do a google search for undertray came up with a lot of bike shit, but theres car stuff in there as well.
cheers.joe.
