LameHoof65
Well, the guy has a good reason, but my head won't be ready for awhile, so I have been taking my time with the cam. I waited until this weekend to finish degreeing and I have gotten some #'s that can't be right.
To begin with I went ahead and set TDC at 4 degrees advance on the crank sprocket. Once I found pos. tdc I started on the lobe center. Now I have the dual pattern 264/274 110* clay smith cam.
Anyway my readings are as follows:
Intake at .050 tdc reads 79* down one side and 169* down the other
Exhaust at .050 tdc reads 53* down one side and 141 down the other
this gives me 124* on intake and 97* on exhaust after dividing by 2.
then for finding lobe center I added 124* + 97* and it comes to 221/2 gives me a lobe center of 110.5* which looks right or close enough. But then that means I am at 14* retard---which I thought should be at 14* advance? I thought advance gave you the low end torque and retard was for torque at higher rpms...Please, someone straighten me out here.
