William,
I tore the front cover off the engine Tuesday night to inspect it....The timing chain & gears are set where they are supposed to be. I cant afford to buy a degree wheel at this time to degree it.
It should be fine being its the same cam I've ran for the past couple of years in the same block
The bottom end is the same as I was running before, just freshened up.
I thought I might have inadvertantly advanced or retarded the cam by mistake when I installed it but thats not the case.
Somthing is screwed up though....Before when you pull the main vacuum line going to the pcv valve off it would instantly kill the motor....now it just speeds up the rpms when you pull it off....
It's running really rich at idle due to the low vacuum which is opening up the power valve IMO. Adjusting the distributor has no affect on it either.
Right now I'm going to rip off the adapter plates and reinstall them with gaskets and permatex sealer, like I did before. I tried a different way of sealing them the last time.....I'm starting to think I have a major vacuum leak that is causin the low vacuum which is in turn causing it to run rich.
Thanks for the concern!!
Later,
Doug
Later,
Doug
