Basic Bottom end---500 miles back:
Block decked by .010
Cylinders board to .040
New moly chrome rings
Crank .010 under
New crank bearings/inserts
New oil pump
Honed cylinder walls
Same cast rods, checked for wear and problems=$500.00w/ labor.
'78 Head (200/250):
Hot-tanked and Magnafluxed $60.00
Milled about .050 for 9.1 compression $60.00
Modified log for direct flat 2bbl mounting $75.00
Complete valve job including 3 angle valve job new hardened intake and exhaust seats and opening of exhaust for FSPP Si valves, bowl work on exhaust, guides, seats, spring shims, freeze plugs, ccing' of head, knurling of guides and installation of guides and seats.....$500
7qt. perf oil pan about $350 (IIRC)
Parts:
FSPP si valves, '79 windsor 351 exhaust springs 12, 4.0v6 retainers, retainer keys...264/274 clay smith cam. dble roller timing chain, FSPP lifters, adj. rocker arm, teflon seals, chrome moly pushrods....complete corteco gasket seat....approximate total for everything about $400 (just my estimate).
Misc. fuel pump, hoses, 2300 holley (500) new air cleaner, FSPP pacemaker headers and locks (Mikes pacemaker kit with ceramic upgrade)-----estimate cost----another $500.oo
You add it up I am afraid too....I still have things to get before getting it in the car and running.....but getting there.
I forgot about the 10 hours I spent with the dremel porting the intake and exhaust....that ought to be at least another $400 for someone else to do.
