electrorc
Hey everyone,
I haven't posted here in awhile, but I have a really dumb question...
I'm looking to replace my radiator again, but I need to get more clearance between it and the fan (stock 4 blade). The cheapest solution is of course just move the engine back, but I've never actually tried to do that. Every time I change the engine mounts, I just let the engine settle where it wants and then tighten the bolts, so it's basically sitting as far forward and down as it can due to the shape of the triangular slot in the mount. I can position it anywhere within that slot, as long as it's roughly equal side-to-side, leaves the engine within a workable range for the u-joint angles, etc, correct?
If so, what's the best way to go about it? I tried loosening the engine mounts and the trans to crossmember nuts, jacked the engine up a little and tried to move it around, but I couldn't get it to actually go *back*. I'm guessing I'll need to try loosening the smaller bolts that go from the trans mount into the transmission to give it more play at the least since the crossmember isn't slotted for adjustment while the mount itself is.
Thanks!
Thanks!
