Hi, yes, it sounds like you are getting there. You should have thread sealant on the front right head bolt because it goes into the water jacket. I'm guessing you never took the lifters out. We used to put a dab of white lube on the valve stems and push rods because it won't go away if the engine sits before starting. I don't put in antifreeze, just water, so if water starts leaking I don't worry about that, until I know it's good. Just don't let it freeze this time of year. If you didn't remove the distributor the timing should be good. It will take some time for gas to get up to the carb, and after that you'll be on your way. Good luck
