10;1 is probably too high, I run 9;1, as to mixers, I run a different thing to you, I not overly keen in Impco, but theyre are available to you, If your running suck through then the 425 is what you need. If blow through you could run the smaller one ca225, keep in mind the air is denser so high mass flow. I would not run rear turbo, too much heat loss, it will lag. Intake manifold isn't that important with boost.
View attachment 29561You are probably better off with two small turbos bolted to the manifolds. Read up on A Graham Bell's book, "forced induction", its very usefull. I run a blown LPG 200ci crossflow here.
