62Ranchero200
Readjusted the valves this week - ended up tightening them about one flat more, and felt much more confident about the process than the first time (have never used adjustable rockers before).
Noticed that the mechanical fan neatly sheared off one of the tie wrap-type attachments for the electric fan, but no harm seems to have been done to the radiator. A noise that sounded like valve train tapping turned out to be the fan hitting a transmission cooler line fitting - one of the fan blades was slightly longer than the others. Trimmed the fan blade with a hacksaw. No harm seems to have been done to the trans cooler line fitting (it's metal, and the fan is plastic).
Set the idle mixture, which allowed the engine to idle a bit lower - about 1,000 RPM in park or neutral. At idle, there's about 12.5" of vacuum, more than I had with my old 200 and the Clay Smith 264/264/110 cam. At cruising RPM, have about 15" of vacuum, rising to about 20" on deceleration. Surprisingly with the 274/274/108 cam, the engine DOES idle in gear once it's warmed up (only have a manual choke at the moment). It idles very low and mean.
Plan to take it on my longest drive yet tonight, about a ten mile round trip.
Need to hook up the A/F ratio meter soon (already have it, the bung is already welded into the collector, and have an opening in the gauge cluster for it) and do some further tuning.
The lower radiator hose hangs down a little too far, have a shorter hose on backorder that should improve that some.
Bob the Builder
Bob the Builder
