255 pistons quickie
80Stang
Sealed Power #478P has 4 valve reliefs, anybody know how much cc they are?
I already ordered these for my next engine project (250), just like to start planning for CR early.
Back to this old topic but does Rick mean the reliefs are 1.5cc each or all 4 together?
Well I can measure that but saves my trouble to measure. Thanks!
1.5 actually sounds like one relief only. 6cc on the piston saves the whole trouble of making dishes to the pistons.
The little chamfer here, is 0.5cc. That may help with deciding whether your 1.5 is per relief, or per piston.
Thanks. Just looked at one piston in the morning and actually there are two smaller reliefs and two bigger ones --- I'll measure to be sure.
I'm at the edge of spending $200-250 on the dishes, unless somebody convinces me that 11.60 CR is great thing to have --- or does 10.80 make any difference anyway...
Being more analytical; save the dish-work money, and boost the octane instead with t________ which I have access to. Costs 2x gasoline, used 4% in the mixture means about $5 more cost per 100km (61mls), so the dish-work price will be zeroed in.....4000-5000km. Being a hobby vehicle, that would be one season only.
Result: it is worth lowering the CR to level suitable for our best pump gas, but maxed out. About 10.80 is my goal.
The pistons I cc'd several years ago measured right at 1.5cc, confirming the Silvolite info. A dish would be good, but it would have to be a big one. Opening up the chamber and fully relieving those valves would be a better way to enhance breathing and gt the CR down to a reasonable level while maintaining quench.
I don't think I'll touch the new alum head. Thanks for the info, maybe I'll measure just to verify that.
fb71: Personally, I don't know anything about that stuff :roll:
:lol: :lol: :lol:
Measured the reliefs, they sure are at 1.5-2.0 cc range all four together.
Have to wait for the head to be able to mirror the chamber into the pistons.
I thought the "t" was Temazepam, to come down from the high of working all night on a favourite toy. :wink:
scare bleu! I know lots about Tolulene. It's a Benzene base chemical thinner which has been used for years as an octane booster. In my opinion, its worse than tetra etyhl lead in terms of environmental risk. Over here in New Zeland, our aromatic hydrocarbon level is so high, a four gas anayliser goes of in any busy street in my town.
Despite my philosphical dislike of the stuff (born through three years as a tar macadam/Bitumen/emulsion technician), I think compression ratio increases are okay as long as the engine is optimised to suit. All tests on conventional GM V8 engines show that increase in compression with no cam optimization causes a loss in peak power. Past 10:1, volumetric efficeincy drops as CR goes up, if the cam isn't optimised to suit. In the case of an old dunger postwar car, going from 6.8:1 to 7.8 or 8.8:1 gives half the % increase in power. Above 10:1, you must optimise the engine to suit, and you don't see those increases unless you add camshaft duration, lift and overlap.
The reason is that if he engine is on the cusp of detonation at 8.8 or 9.8:1, then at 10.8:1, you'll be right on to it, even if you octane goes up from 96 to 105 by the addition of tolulene. To use 10.8:1, you've got to retart cam timing to get cold cranking compression below 190 psi. Then you may have to fiddle with ignition timing.
The plus is that any engine with any compresion increase always yields significantly better part throttle fuel consumption.Peak power may flat line, but part throttle economy goes up.
