cameljockey
Please bear with my ignorance
The following musings are predicated on my suspicion and the suspicion of some others I have seen on another thread that the Yella Terra shaft mounted system is merely an adaption from another motor. (I don’t really know I’m just being Suspicious Aloicois)
1st off I THINK (just my un- informed opinion) stud mounted full rollers are easier to adjust while the engine is running b/c the adjustment is at the fulcrum instead of at the push-rod. Better adjustment means more stability through out the RPM range & longer valve train life, right?
2nd They are cheaper! Almost half the cost of the Yella Terra shaft mounted system. (depending on the vendor of your choice)
3rd high RPM stability is not an issue for the Ford in-lines if I understand correctly they don’t like the REV’s at least the 250 CI does not like to rev past 6000 if we’re lucky! (a stud girdle would be a simple affair I think; but valve cover clearance might pose an issue)
4th did I mention they are cheaper!
5th we could use the same approach for adapting them to our head as the Yella Terra system which looks to me like a properly sized piece of bar-stock with holes in the right locations.(bar-stock is CHEAP!)
I have been pinging some folks at different rocker arm houses around the country.
Compcams is mum so far but I am in touch with a technical consultant over there who is “looking into it†right now. :roll:
Harland sharp has suggested using their PN S4002 (see: http://harlandsharp.com/inlineford_amc.htm)
These are meant for the 240-300 Ford 6 if the distances across the head are the same y not? I need to look into this still. But if the distances are the same shouldn’t the angles be also? (By which I mean when the engine is off and the valve closed at TDC the angle between the pushrod and the vertical ideally 90 deg right?)
I have yet to contact Jesel but every thing they make is usually prohibitively expensive even if it isn’t a custom piece.
Besides which there are warranty concerns that get raised with an “off label use†which makes any of them some what reluctant to make a suggestion.
Questions that I think need to be answered in order to find a good alternative:
1. valve-stem installed height (known from any manufacturer who makes em)
2. valve-spring diameter (ditto)
3. anything else?
If all else fails I will take a rocker arm off of my spare assy in the shed to my local Pick Your Part with my vernier calipers and start comparing there IN the Yard!!!! (I really want and answer)
This is a problem that has weighed heavily on my mind since I joined this forum.
Keep Sixin`
3. anything else?
Keep Sixin`
