Good one, Adam!
I don't drink, so any help will be welcome
Seriously, like Inliner said before, these heads are already being built and raced. What I meant is that the first head is in USA now, getting ready to rock. I hope we can bring you some dyno numbers as soon as possible.
About the aluminum, I don't have the specs with me, but it's an special alloy (notice the colour on the non-machined parts), stronger than most alloys used for cylinder heads, structural (and, above all) thermally wise. For example, something that really impressed me, was that they can be used with steel shim headgaskets. If you want to use a composite one, the Felpro unit it's perfect. The deck thickness is huge, and special care has been taking on critical areas (like at the rocker arm posts mounts) to assure not only valvetrain stability, but also long lasting performance. The particular model being built for SCP has some differences with the race model, since we are not limited by class rules.
For the casting process, the designer uses more than twice the amount of aluminum needed, to avoid porosity issues. This aluminum alloy it's not easy to work with manufacturing process wise, but it helps the head survive under the stress of racing. And of course, it's heat treated.
Furthermore, the test is going to be performed with an off-the-shelf US cam, althought we are working on custom made grinds that will extract every single bit of power these heads can deliver.
