Burge_Man":36ezo0xk said:the day hp numbers are posted this board will explode
I think you are right....
WhitePony":1q38nksx said:The problem is, people here want to see some true HP numbers in a real world setup. Your web site has said "Dino day comming soon" for several months now.
Southern Cross Racer":2cu3ssng said:Expect pics of an argentinian drag racing falcon (360 hp@6000 rpms) sporting one of the al heads very soon.
Southern Cross Racer":2q2xpvvf said:I think that soon enough, there will be a few cars featuring the head, and trust me, the buyers are serious about power.
Southern Cross Racer":2q2xpvvf said:I hope this product will raise the bar high enough so the inline six crowd will be able to battle head-to-head with Vee-Eight guys
no need for patience, i've got stuff comin in soonSP AluminumHead":33t0zxns said:patience grasshoppa
asa67_stang":28gtelb1 said:but i'm sort of flabbergasted to hear that you guys are selling these without dyno numbers
Southern Cross Racer":28gtelb1 said:taking advantage of the 30+ racing expertise we have here in Argentina with these engines..
asa67_stang":11gb8kt7 said:but what about the stock 200 that you were going to test it on?
asa67_stang":11gb8kt7 said:360HP is possible, i'm sure Does10s could do that with a bit of giggle gas and some mild building
but that's not a stock engine
SCP is putting the SP head to the test. Just how well will a "SP" cylinder head perform on a common street driven 200 engine? Stay tuned.
Current engine specs:
- SP head and intake, cleanup porting job, 3 angle, 1.75" / 1.50" valves, 9.5:1 CR
- 200 block, stock rods & pistons, SCP camshaft
- Duraspark II & Holley 500 carburetor
anyone who wants to get proof of how much power the head alone will addLinc's 200":2m5ae6ct said:asa67_stang":2m5ae6ct said:but what about the stock 200 that you were going to test it on?
Ya talkin' ta me?? 8)
HONESTLY NOW - who would bolt this head on a "STOCK" engine??
a stock 250, with a cam shaft change, an upgrade in ignition, ARP fasteners, and a turbo will send a car down the 1/4 in 12 secondsLinc's 200":2m5ae6ct said:Besides - - - - Inliner, Southern Cross Perf and Aluminum SP never said they would try to get 360 HP from a stock engine with just a head swap, they are just providing some examples of what the head is capable of.
65coupei6":3strwtoo said:To make a car with that much power is going to cost a little more than just adding a head.
Linc's 200":1plw502b said:I have been around engines for so long and have been doing this for so many years that I would never assume the claims are based on a stock engine.
To be really fair, someone needs to test a few heads on the flowbench (stock log, aussie 2V, argie iron, alum SP) and then that data can be used (within a reaonable error range) on computerized engine simulators, and you can get an idea from that. It would save a lot of dyno time and $$$$.
