Another granada owner
Hello everyone, I own a 79' ford granada with the 250. I want to get a little more out of it, i've already got the exhaust done with no cat. Now i want to remove the rad fan and install an electric one. What belts would i need to do this also would i need a different radiator?
I would think that the radiator would not have to be changed. Also, Can you not use the stock belts? I was thinking that the fan just bolts to the water pump pulley. If it does you wouldn't need to change them. Please correct me if I'm wrong.
HAY 79greenada
The fan just bolts to the pully you steal need the pully and belt to drive the water pump. You well steal gain some poines cause you not driving the fan it actualy does pull it down some noticably..
tim
