Autolite 1100 on 200 inline six
Dear members, I have done my due diligence and have installed a new tank, cleaned the lines and installed the carburator with the adjustments indicated in the manual. Today I started the car and after some hard strts it started, However, when the car was running it stopped all of the sudden. Restrated again and it did the same thing. I made a short visdeo to show waht is happening. I am goinfg crazy with this situation as I see no end to it. Could someone give me some suggestions to get the car running? Appreciate your comments.
A couple things, unless it is new too, remove the screw in filter from the carb, empty gas from it, the blow thru it, there should be very little restriction.
I noticed a pressure guage, is that before or after the pressure regulator?
I don’t like the choke being shut. If you adjust it to fully open, does it change?
What happens if you turn the idle up to 2k ish, will it keep running? With the choke open? And with the choke shut?
We are trying to determine if it is the carb or something else.
Thanks for the vid! That is your ignition cutting out. It is not the carb. Heard a 1/4 second miss first, then boom, instant cut off. That's spark. Carbs issues don't react that abruptly.
Don, Car was cold to start. Can not get it to run continuosly. Tank is brand new, lines have been blown. THe reguator is after the pump, there is no gauge. Regulator indicates a pressure of 3 psi when is cranking and when it runs for a few seconds.
Frank, I am thinking of getting a new condenser and I will see if the coil is good. Other than that anythigelse that I shoulld look into?
Thanks for your comments Don and Frank
Just tested the coil and there is a good continuous spark.
Put a timing light on the coil-to-distributor wire and leave it on while running the engine. My ear still says ignition. If the lights still on when it stalls, I'll admit wrong.
When I first got caught up in this inline-6 community, I read a lot of stories about bad ignition condensers. It might have been a bad run at the time 2023/24 but I read several discussions where the car was parked because of a bad condenser, right out of the box.
here's my $ .02
had' recent episode with 'new' points ignition set - 'condensor' on a friends '63 Comet 200 . Maybe thermal or chemical fault , intermittent cut out after initial start. 'Simple' help with tune up turned into an episode .
To ease doubts about the fuel supply, I use a small tank underhood without fuel pump and gravity feed to the carb. This helps isolate tank or FP related problem .
I guess I was assuming the guage outlined in the photo was for fuel.
I am back with this issue. I just bought a new condenser and installed it. Before I try to start the car I wanted to do a static timing to see how far or good approx is the timing/ I pulled the number one spark and it has a lot of carbon, which to me if I am npt wronh the car is runnung rich. (please see the pic). I getting the number one cylinder to TDC, I went a little past and fonud that the BTDC is at 5 deg and the points are at 0.025 gap. From wwhat I have read the gap at this 5 deg shoukd just be opening. Since the car is an automatic I need to go and set the timing at 12 deg.
Any comments or suggestions will be aappreciated
HAve not taken them out yet, I will today. Your comments makes sense since I also have not been able to adjust the choke. Thank you for your comment.
Gentlemen, Further to my woes, as I am trying to preliminary adjust the timing statically and see if I can get the engine to run continuosly, I found that the TDC is way off the engine timing marks, which I think is way off. I checked the perimeter of the harmonic balancer and there are no ther notches that could possible be nearer the timing marks. Please see the enclosed picture. Does this means that the notch inthe balance has slided? What should I do next? Please ypur comments are apprec iated
These are good procedures. However, I'll humbly say again that carburetor issues ease in and ease out. Your video demonstrated an engine with instantaneous 1/2 second cut-out, instant return to rpm, then instant stall. That is symptoms of the ignition, not carburation. Neither choke nor mixture produce that instant engine response.
You can verify immediately with a timing light. Not aimed at anything, just flashing all 6 sparks off the coil-distributor wire. Run the engine. When it starts to cut out, the light will cut out too. If it cuts out and the light had no break in it's flash, then you know it's fuel. :)
Forgot to mention that the rotor in the distributor points to the number one cylinder. Also I verify that tha cylinder on in the compression cycle and that the piston was at the very top
Frank, I need to get the car running and that why I am trying to eliminate variables by trying to approximate the timing. What should I do to close the gap bewteen balance and enngine tiiming lights? Comments please. THanks
The timing didn't sound terrible from what was heard on the video. Point being, figure out why it's stalling first. If the timing was way off it would not run. Fine tuning comes after the bugs are found and corrected.
Just thought of a possible cause for (what I think) is the ignition going from perfect to randomly cutting out: the distributor may not have a good ground to the block. . I've rarely heard this presented by anyone including on this forum. However I know from experience that if the distributor looses good contact with the block from age/grease/rust, the circuit is broken and spark stops. You're searching for an anomalous type miss fire. Only a few things will cause a fully firing ignition to cut completely out/in/out. Timing is not among them.
Are you running points? Be sure they can ground sufficiently. Should have a wire on the breaker plate grounding to the distributor body. After my stranding on the interstate 43 years ago I also run a ground wire from the distributor body to the block. Recommended. Something besides points setting and timing is causing what was on the video.
Distributor ground wire attached to the vacuum advance hold down screw-
Thank you Frank for your comments. As I was trying to get the crank to be at the 12 deg position, I started to trurn the distributor that was on TDC (point gap was open) i checked and found that the points are grounded, meaning the test light that I connected to the neg side of the coil the light remained lit. Point gap open light should be off. Been checking the different forums and the only thing that I found was that there was short on the wire comming from the switch to the coil. Really do not understand what that means. Could this be a cause for the stalling?
I have checked and there is a wire o the braker plate, I will check for the grounding of the distributor tomorrow.
Appreciate all the assistance.
Previous 12 volt automotive tech here… I think that discussion you read is wrong of maybe the pertinent information got lost in translation. On a points/condenser distributor, the ignition switched power, energizes the positive side of the coil. The negative side of the coil connects to ground through the points. This means that when the points are closed, you will see ground on the negative side of the coil but when the points are open, you will see positive voltage.
If the points were closed and you still saw power (on the negative coil terminal) that means that your points aren’t grounded through the distributor which is what @Frank illustrated. If that’s happening then @Frank’s fix will certainly resolve it by putting your own ground on the distributor and taking it to the engine block or the chassis.
On that note, double check that your engine has a good ground strap. The distributor grounds through the block where it’s mounted. It should have a good ground from the tight fit of the hosing in the block and from being clamped in place. I would check continuity between the distributor base plate and the block and also between the block and the negative side of the battery and the chassis. It might be something as simple as the chassis and block not being grounded. There should be a braided strap between the engine block and the chassis and the negative terminal of the battery should be bolted to the block as well.
Be careful when using a test light; when the points open, they will ark and will send a pulse through the negative side and can take out an incandescent test lamp. I’m not sure how well a LED test light will fare either. I’ve never tried one on a points ignition.
