bummed about 2v installation
CoupeBoy
2K+
Well we finally got around to putting the homemade 1 to 2v adapter on my buddy's '66 with the 5200 that I rebuilt.
Lets just say that the results were less then stellar.
We put it on, cranked it over a couple times to get gas into the carb, pumped it a couple times it fired right up (yay!), worked the throttle a little, which worked like a champ (yay) cracked it all the way open and it died, flat on its face (bummer!). I thought maybe it was the carb to adapter bolts not tight enough, (with the carb floats facing forward the bolt right under the choke assembly is damn near impossible to get on with a socket) so I cranked em all down a little more and tried it again, same results :cry: When you hold the choke open you can work the throttle and the engine will speed up and slow down accordingly but as soon as those choke flaps open, it flops right on its face. We also didnt have anything to spray around the carb/adapter when we had it running, so that didnt help during the trouble shooting process.
Best I can figure is that either my adapter has a HUGE vacuum leak, on the bottom, or through the bolt holes. Or I did something wrong inside the carb when I rebuilt it (it could happen). The bummer part is that he might be moving, with his car, this weekend up to Pullman and he does not want to mess with it on his own, and I am moving to Fargo next monday, so I have very little time (if any) to try this one more time. So I am hoping for some suggestions/recommendations from anybody who has done this upgrade before. I think I need to have the adapter milled down a little bit more on the sides so I can get a wrench under it easier for holding the bolts and if another is ever made tap the holes and put in some short studs.
Do I need a thicker gasket under the adapter?
Is there anything tricky about rebuilding the carb?
Should I toss on my stovebolt adapter with the carb on a little crooked? (ala ducktang)
burnrelief any problems with your install?
-ron
Ron, I had no problems. Fired up and ran good after adjusting the linkage, tuning the carb and re-setting timing. --- I'd look at the timing and air-fuel mix if you haven't yet. -- Also, was the car warmed up when you hit it? If not that could contribute to the problem.
Sounds like you're leaning it out when you open the choke? -- can you hear a vaccum leak?
Its hard to tell if you can hear a vacuum leak or not when you run without an air cleaner and dont have any solvent to check for leaks at gaskets. The inside of the carb was nice and wet, I cranked out the air/fuel mixture screw (made no difference) I did make sure the jets were open on the inside when i rebuilt it. I want to look at its innards again to see if I possibly got a peice of "foreign material" in there somehow, other then the constant dying problem, it had a much better throttle response then his current 1100.
Oh ya, some pics of your linkage would be nice :lol:
-ron
Ron,
If you are working on it this Sunday, I may be bale to come by and lend some moral support, or bring any tools you might need.
Bill
thanks for the offer Bill however Sunday I will be packing, our problem is coming down to time. He wants to take his stuff up to WA this coming up weekend, leaving saturday not sure which of his cars he is taking (he's got 4) and the mustang might be the one to go. If not the week of Memorial Day I will be back and will have time to play with it then (everynight after work) for that week, then he is moving up permanently to Wa and time will be up.
-ron
Hmmm,
I have a birthday party for a friends one year old on Saturday, but I can help after work that week if you need it.
Bill
