Howdy Back trashline:
Given your perameters, I'd recommend an Autolite 1101 Used on '69 250 engines in the FoMoCo fleet. It is very similiar in appearance to the 1100, but a 1.20" venturi as opposed to a 1.20" in the 200 engine 1100's. CFM differences at 185 for the 1100 and 210 CFM for the 1101. That is a difference you will notice. It will take a very trained eye to recognize it as not OEM. You will lose the Spark Control Valve for your Load-A-Matic, vacuum advance only distributor. You can upgrate to a later distributor (Best choice), or you can use manifold or ported vacuum (users of both have reported varying results), or you can increase the initial a bunch and run without vacuum advance (NOT a good idea, either for power or economy).
You may need to enlarge/taper the spacer under the carb to clear the larger butterfly of the 1101.
Your linkage, Choke heat riser and air cleaner should be a direct bolt on.
